RED REDUX (256b Intro) - Virtual Vision Group
https://zxaaa.ru/view_demo.php?id=14687
Re: RED REDUX (256b Intro) - Virtual Vision Group
       .00000&,       .000000. &00000&       .@@@000.%&@@@@@@@@@@@@@@
        ,@@@@@@%.      &@@@@@@@@&@@@@@&     .@@@0000&#.@@@@@@@@@@@@@@@
        .@@@@@@@@.     #@@@@@@&@%@@@@@@     @@@00000@.@@@@@@@0@@@@@@@&
         .@@@@@@@@.    %@@@@@@@@%@@@@@%   &&&@000000.@@%
          .@@@@@@@@@.  %&@@@@@@@%@@@@@@.,@@@@0000%.@@#
            .@@@@@@@@%.&@@@@@@@@%@@@@@@@,@@@@@000.%%%&
              .@@@@@@@@@@@@@@@@@%@@@@@@@@@@@00&%.@@@@        .&&&&&&&
                %@@@@@@@@@@@@@@@%@@@@@@@@@@@@00.%@@@@.       &@@@@@@@
                 .@@@@@@@@@@@@@@%@@@@@@@@@@@&0.%@@@@@.       @@@@@@@@
                      @@@@@@@@@&%0@@@@@@@@%   @@@@@@@@@@@@@@@@@@@@@@@
                         #&@@@@% %#&@@@# 2o25  .#@@@@@@@@@@@@@@@@@@@#
        RED REDUX 256 byte intro - a contribution to Multimatograf 2025
                         by Virtual Vision Group.
                         for ZX Spectrum 48K+AY
                        and also ZX Spectrum Next
  This 256 byte intro refers to Red Supremacy,a 4KB intro released earlier this
month at Speccy.PL Party 2025 (https://www.pouet.net/prod.php?which=103873).
While the visuals here convey the basic idea, calling it a "redux" is of course
tongue-in-cheek, as the 4KB intro has much much more in it - go watch it if you
haven't.
  The intro is supplied both as a 48K+AY and as a ZX Spectrum Next binary, but
it had been entered in the classic (48/128K) compo. I decided to pay respects
to the original platform (plus it doesn't benefit from the Next capabilities).
  HOWEVER, this means that unlike many 256 byte intros for 48/128K, this intro
does not use any ZX Spectrum ROM routines.
  I think this is the first ZX 256b intro that plays a Protracker (or simply
non-trivial) music. I haven't extensively checked all of them, so feel free to
correct me if I'm wrong.
                                 Credits
  - Code - RCL
  - Music - Kenotron (with modifications by RCL).
                                How to run
  For the 48K + AY / 128K version:
  - Just load the provided .tap file that contains the BASIC loader
  or
  - Load the separate code block at 24576 and run it:
        CLEAR 24575: LOAD "" CODE: RANDOMIZE USR 24576
  Note: if you don't turn on the sound or don't have the AY, you will be rather
disappointed.
  For the ZX Spectrum Next version:
  - You can run the .dot file anywhere from the SD card using NextZXOS browser.
                               Under the hood
  This was born out of my music compression experiments while working on Red
Supremacy. I noticed that the beginning of the (excellent) Kenotron soundtrack
(originally from Voodoo invtro from 2000 by the way) had a rather simple
structure and stood a chance to be redone to fit a 256b intro format.
  Of course it wasn't that simple. The music structure wasn't regular enough
to rewrite it in the code, so I decided to compress the register dump. A
pattern of music (64 notes) with tempo 4 takes 256 bytes per AY register, so
I was looking at compressing up to 3584 bytes into <= 256. Gladly, as I said
Kenotron's track was somewhat simple in the beginning so it only needed values
for 12 registers, one of which was a constant. That simplified things but still
the result compressed to about 200-220 bytes, not leaving much space for the
player or the decompressor routine (I used ZX2 with some minor mods).
  I had to make compromises and reduced the AY register update from once per
frame to once per 4 frames, effectively bringing the dump size to 1/4. Most
of the track was regular enough to allow that with minimal differences for
the ear, but the kick in the beginning noticeably suffered. However I still
wanted to have at least some visuals so I had to leave it at that.
  First version of the code ran fine and was ready for submission, but when
doing a soak test on my real Spectrum 48K+AY, I noticed that it would stomp
the memory and lock up after several minutes of running. While I judged that
practically unimportant as no one would leave it running for that long, it
didn't sit well with me. I rewrote the code so it can now run indefinitely long
without any ill effects.
  As I said above, due to the code being able to run both on 48K/128K and the
Next (within the same 256 byte limit), it is self-contained and free from
any ZX Spectrum ROM use. Ded aka Unbeliever aka MMA would approve of this :-)
  Expect the sources on github shortly after the party.
 -RCL, 2025-04-26
Вроде музончик из инвитки СС - не помню год.
Да, музончик старый...
https://zxaaa.net/view_demo.php?id=1129
гы, я аук в 256б тоже запихивал(:
